1 - 9 of 9 Posts
Discussion Starter #1
used the search, sorry guys. I turn on the high beams and the lights go out!LOL Bulbs, switch, ideas?
more than likely the switch, do they work when you pull the switch back (flash to pass)?
Take the bulbs out and look at the filament. Usually if the bulb is bad you can see where the filament is burnt into two pieces. Most likely it's your switch. I've had to replace the switch on my '88 a couple times for the same reason.
Discussion Starter #4
They flash, so Im gueesing the bulbs are fine. So I should replace the switch huh?
yup, switch it is.
91stevengt said:
i got a new altenator battery wiring harness and fues box but my battery keeps going dead
how do i fix that
use an ammeter to measure draw on the battery with everything turned off. start pulling fuses one by one until you find the one that is causing the draw.
1 - 9 of 9 Posts
