No heat, fan stuck on high | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by tonepaq, Apr 28, 2010.
  1. tonepaq
    tonepaq New Member
    6
    I have an 02.
    The heater will not blow hot air, just cold. Acts like the AC is engaged no matter what I select because the fan on the radiator turns on high speed at any setting.
    Any ideas?
  2. metrotps
    metrotps New Member
    23
    Everett, Washington " The Everwet State "
    When the car has sat over-night check the coolant level in the radiator. The surge tank might look OK but the radiator could be low.
  3. homestead367
    homestead367 New Member
    516
    Indianapolis
    Coolent temp switch may have gone bad. The high pressure switch on the A/C might be reading high. Which would cause the fan to stay on high.
  4. bisjoe
    bisjoe FEOA Member
    122
    166
    Sammamish, WA
    The resistor that governs the speed based on switch setting burns out frequently, they glow red hot on all but the fast setting. That's why the fast setting is all that's left when it goes out. They are inexpensive ($10-$15) and fairly easy to replace located in the fan housing under the glove box.
    Still, that doesn't explain the A/C and no heat. In addition to the suggestions already made, the thermostat could be stuck open. You can tell by feeling the heater hoses with it warmed up and heater on, both should be hot.
