welcome!
first of all, spend $20 on a digital voltmeter and $20 on a Chilton's manual if you don't already have these. The manual will have generic wiring diagrams that you can use as a guide.
are there any other electrical problems? do the parking lights and headlights work? do the turn signals work? hi and low beams work? radio works? rear windshield wiper works? any problems starting the car? If any of these are still working, then it's not likely to be the ignition switch. Not saying it isn't the switch, just not likely.
check the negative connector at the battery. On these Escorts, there's a secondary ground connector for various electrical circuits integrated with the main negative ground clamp. Make sure this secondary connector isn't loose, frayed, broken or corroded. If it is, fix it.
If all of the above passes, then this problem is going to require some electrical sleuthing and I recommend that you work on one problem at a time. The 2 problems may or may not be related; if they are related, then diagnosing one may solve the other. I don't recommend that you just guess and throw parts at it; you'll quickly get frustrated and have an empty wallet to boot.
Turn the ignition key to the "run" position
go to the fuse panel in the cabin (driver's side footwell, I think) and use the diagram inside the cover to identify the windshield wiper fuse. Pull the fuse and look at it carefully to make sure it's not blown. If there's corrosion on the fuse blades, clean it off or replace the fuse. Put the fuse back in and test. If the wipers still don't work, try wiggling the fuse with the wipers on. If the wipers still don't work, pop the fuse again and check for 12V at each of the contacts in the fuse box by touching one lead of the meter to a contact and the other to any nearby metal. If you don't have 12V at either contact, then you've got a problem with electrical supply to the fuse.
If you do have 12V at the fuse, put the fuse back in.
Go to the fuse panel in the engine compartment and check all the fuses. Identify any relays (big square boxes in the fuse-box) that might be associated with the wiper or the blower, pull them out, clean the blades and re-insert. Don't try to diagnose the relays, yet.
Find the connector to the wiper motor. Carefully disconnect it, turn the wipers on and check each terminal for 12V by inserting one test lead from the meter into the connector and touching the other to any nearby bare body metal. If you don't have 12V at any terminal, you've got an electrical problem between the fuse and the wiper motor. If you do have 12V with this test, find the ground connector in the terminal (likely a black wire) and test again with the other terminals one at a time. If you don't have 12V, then you have a ground problem. Double-check the ground in the connector by setting the meter to "ohms" and touching one test lead to the ground terminal and the other to bare metal. You should get zero or close to it.
That should keep you busy for a while. Let us know how the testing goes and we can offer other advice based on the results.
