Electrical - No Heat/ac! | Ford Escort Owners Association (FEOA)
Electrical No Heat/ac!
Discussion in 'ICE (In Car Entertainment)' started by Tebowshaved, Dec 27, 2013.
  1. Tebowshaved
    Tebowshaved New Member
    Everything was working fine before I installed my headunit! I wired up an after market kenwood tonight and hat works great. But after doing that, none one my blowers work now. No hear, or ac. They worked fine beforehand but I can't figured out shat is wrong! Any help or advice would be great! Thanks!
    It's at 2000 zx2
  2. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    trace your steps in reverse. there isn't much else i can say with out being there in person.
  3. Intuit
    Intuit FEOA Member
    7,585
    949
    Southwest Ohio
    Test your fuses. Disconnect the radio and see whether the blower resumes operation. Test at the blower motor harness to see whether power is reaching the motor. Test resistance at the blower motor harness/resistor to ground; assuming the dash switch controls ground-routing to through the resistor assembly. Remove the motor and supply 12v directly to it. (watch those fingers!)
  4. 4cylinder
    4cylinder FEOA Member
    737
    138
    193
    san diego, ca
    your problem is the connectors on the switches and maybe the HVAC harness. This is a common noob mistake. Take the adapter out again and make sure that you plugged the vacuum switches into the switch on the right. Once you do that you can put the assembly back into the car. Be sure to plug the large white HVAC plug back onto the harness as well (this is the one which has all the connections leading to the switches).
