1 - 6 of 6 Posts
I just ordered the msd coilpack from zxtuner.com for my car and i just ordered ngk iridium plugs from advance auto parts. I also ordered the fuel controller from escortfocus.com also. Im hoping to get a nicer powerband from this. I already have the 8.8 accel spiralcore wires. any comments???
the msd will definitely help to burn all the fuel, you might see 1 or 2 horses of a gain, but don't expect too much. However, you can expect better gas mileage.
It won't do alot for peformance. But it will smootrh out yout idle and make teh engine run alot nicer. Its got a much stronger spark than the OEM coil pack.
John
Administrator
exactly.. miight... 2hp is a lot of power. youll get a smoother idle and a smoother powerband but its not going to do what you expected... not any neck breaking power.
Agreed. It's mostly just an efficency mod. I have the MSD coil pack and Magnecore wires and it ups mileage and smooths out the idle a little. Also throttle response is a little nicer but other then that, no real power gains.
if you were to get the add-on ignition module from MSD, then you wiuld see better power gains, due to their Capacitive Discharge system, IE Multiple sparks per cycle. With the msd coil alone, you'll get a much more powerful spark, but it is still just one spark.
1 - 6 of 6 Posts
