Newbie needs help with codes! | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by Mjestes17, Jan 13, 2020.
  1. Mjestes17
    Mjestes17 FEOA Member
    11
    Hey guys! Can someone decipher these codes for me please? Video link here:
    I've thrown a bunch of brand new parts at this escort I bought for $100. New PCV, spark plugs, TPS, IACV, Battery, battery terminals, etc. Has a rough idle that imitates a cam lope and once I installed the new TPS and IACV it revs really high and stay at 1700RPM while continuing to accelerate down the road without my assistance.
  2. Swift
    Swift FEOA Donator
    478
    91
    278
    What kind of iacv
  3. Mjestes17
    11
    I believe (without being home) it's Standard brand
  4. zzyzzx
    14,763
    1,106
    What year?
  5. Mjestes17
    11
    1993 1.9L automatic
  6. marclar
    8,805
    483
    383
    seabeck WA
    did you install the iacv in the same orientation the old one was?
  7. Mjestes17
    11
    I mean, I installed it upright the way it's supposed to be installed lol. I did notice that the electrical plug faces the opposite direction though.
  8. zzyzzx
    14,763
    1,106
    This would be 2 digit codes, correct?
  9. Mjestes17
    11
    I assume yes from what I've read, but I'm new to this car and don't know for sure. That's why I was soliciting the help of everyone else
  10. marclar
    8,805
    483
    383
    seabeck WA
    the reason i ask, is because the pintle is spring loaded for one direction. if its backwards, it can be forced open by incoming air.
  11. Mjestes17
    11
    So it would matter if the electrical plug was reversed? I got one from a 1994 then replaced it with a 1993, neither of which solved the issue
  12. zzyzzx
    14,763
    1,106
    I see codes 57, 58, 71, 72, and 81.
    Having written that, my 1995 uses 3 digit codes.
    57- Idle Tracking Switch Circuit Open Or Grounded.
    58 - Vane Air Temperature Sensor Input Greater Than Self Test Maximum.
    71 - Software Re-Initalization Detected OR Insufficient Manifold Absolute Pressure/Mass Air Flow Change During Dynamic Response Test.
    72 - Power Interrupt Software Re-Initalization Detected.
    81 - Secondary Air Bypass Circuit Failure.
    Someone else here should verfy all of this.
    I am more sure about the 57 & 58 codes, and that code 57 is probably what is causing your idle issue.
  13. Mjestes17
    11
    I never saw a 57 on the code list. What are those?
  14. zzyzzx
    14,763
    1,106
    EEC-IV two digit codes, as per the internet.
  15. zzyzzx
    14,763
    1,106
    The Idle Tracking Switch (ITS) is part of the IAC. So it's the IAC, or the IAC circuit. Or possibly a TPS, or a TPS that needs adjustment? I would be looking at those two the most.
    What brand replacement parts for those did you use?
  16. Mjestes17
    11
    I've replaced both of those and nothing helps! Both are from Oreilly Auto, STANDARD brand on both.
    I removed the throttle body, cleaned everything, ensured it closes completely and reinstalled everything. Still continues to accelerate, revs extremely high when I put it in neutral or park, and then chokes while idling. Only got 23mpg on this last tank because of the RPM issue
  17. marclar
    8,805
    483
    383
    seabeck WA
    71, 72, i would be checking engine and body grounds first before doing anything else.
