New overhead light option(LED Map light added page 2) | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in 'Interior Modifications' started by Dave94LX, Nov 27, 2010.
  1. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    My 3rd gen originally came with the single overhead light with no map lights. I had grabbed this unit from the junk yard. I can't remember if I got it from a 2nd or 3rd gen off hand.
  2. pextor
    pextor Moderator Staff Member
    5,932
    791
    Lancaster, pa
    I know, I was probably along with you when you got it :)
    I don't remember what it came from, I was just noting the difference between it and the one I have for in my car.
    was the main light bulb 31mm overall length? because mine is longer in the 3rd gen housing.
  3. Dave94LX
    5,787
    238
    Under the Stairs
    Actually, I am pretty sure you were with me. I had thought I pulled it from a 3rd gen, but it's possible that I may have gotten it out of a 2nd gen. Both mount and wire up the same.
    mine are both 31mm. The standard overhead light housing has a longer bulb. I actually have a longer LED bulb that I had bought for another project. If you want to swing by some time, we can see if it fits in your housing.
  4. pextor
    5,932
    791
    Lancaster, pa
    I gotta visit the little rascal sometime.
  5. Dave94LX
    5,787
    238
    Under the Stairs
    He wont be home for a little while yet, so you have time. Hopefully sometime next week or the week after.
    Unless you meant visit at the hospital... then just give a call some night, and see if we are over there. We are usually there daily.
  6. pextor
    5,932
    791
    Lancaster, pa
    not in the hospital, no.
  7. LeraiPalmer
    LeraiPalmer New Member
    156
    Milwaukee/Tomah, wi
    WARNING-THIS MOD ATTRACTS CRACK HEADS!!
    I just did this mod yesterday. Only takes 5-10mins. I bought the 16 led tho ( http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0727857264 ). Removed the metal heat shield thingy. Had to push the metal contact clips to the max to fit that sob in there. Waited till 10pm...hit the switch and felt like the police had the high beam on me! I couldn't believe the difference. What sucks is that 20s after i turned em on, a crack head saw me right away and asked me for a ride to 4th and Burleigh st.
  8. LeraiPalmer
    156
    Milwaukee/Tomah, wi
    BTW...what part number is for the light thats in the trunk and hood for the 2nd gen? Id like to get LEDs for those as well.
  9. Skuce
    Skuce FEOA Member
    3,307
    5
    288
    Ontario
    Super cool! 8)
  10. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
  11. chris98escort
    chris98escort New Member
    41
    Shepherdsville, KY
    hey dave how did you go about modding the map lights i got the LED's just like that and i see you used the normal bulb handle how did you go about doing that?
  12. Dave94LX
    5,787
    238
    Under the Stairs
    You may have the 194 style LED bulb rather than the 168. If you have a flat style prong on the stock map lights, then you need the 194 bulbs.
  13. Kostaccio
    Kostaccio FEOA Member
    43
    16
    The first thing I usually do to any daily drive I own is replace interior lights with LED bulbs. My 87 Escort has LED map/interior lights which are fantastic, and I also have an LED license plate light. I think the turn signals in the rear will be the next to be switched to LEDs. With only 2 interior lights up front, LEDs make a world of a difference when the door is opened when its dark.
  14. jo64tt
    jo64tt New Member
    14
    just did my first led upgrade to dome light, and trunk light..super addictive..want to get more dont have an idea what i should do next
  15. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    LED dash bulbs are great. You can get 10 colored LED bulbs off ebay for less than 2 incandescent bulbs at wal-mart. Unsure local laws, but plate lights are nice. If you do the turn signals, you will need a resistor or "electronic" flasher so they don't blink too fast.
  16. 404ninja
    404ninja New Member
    16
    I just got mine and installed it. So much better.
  17. edglenn
    edglenn New Member
    19
    Removing lens cover to put in l.e.d.'s?
    I tried to remove the lens cover of my dome light, but it didn't want to pry off. I didn't want to force it and break it.
    It's on a '97 w/o map lights. It just didn't feel like it wanted to pop off.
    Pry harder? Is there a screwdriver slot I didn't see?
    Suggestions?
    Thanks.
    (This ain't my first dome light, in case you're wondering)
  18. RcCarRacer1992
    RcCarRacer1992 FEOA Member
    491
    10
    168
  19. cwol97401
    cwol97401 FEOA Member
    701
    221
    193
    Midwestern Oregon
    i know this is an old thread but do you know how you got your guages re colored? I'm tossing around the idea in my 3rd gen
  20. dmitri15
    dmitri15 FEOA Member
    95
    4
    158
    Minnesota
    Buy whatever color LEDs you want. Dismantle your cluster. Use carb cleaner or nail polish remover to remove the green. Reassemble. Call it good.
