1 - 9 of 9 Posts
Just installed my new iac, and it works great again. I couldn't believe my throttle response and how much smoother the whole car feels. Just thought I'd let you know.
alright, you two... take it to springer...
concerning the new IAC though...
did you buy one new from mazda or something? Cause I have a weird problem where my idle drops to around 1000, then down to 500, then oscillates. I heard that the problem was either the ignition module or the iac and I was wondering exactly what the iac fixed...
Discussion Starter · #9 ·
That kind of sounds like what mine was doing when I had to replace my tps. Right after I fixed that my idle wouldn't drop below 1100-13 or 1400 rpm and I had no vac. leaks or anything else to be found wrong. So a ford mech. told me I needed the new iac. I had cleaned it but, I didn't change anything. Then a friend of a friend got me one . I had to go through Mazda, to get the gasket. Ford doesn't offer them anymore. Put it in this morning and everything is right again. Now I need an intake and exhaust system. Any suggestions on getting it up to about 175 hp or so are welcome, I need to start forming a plan. what kind of gain will I see with an intake and exhaust system?
1 - 9 of 9 Posts
