1 - 12 of 12 Posts
Q #1. Is the 9:1 compression ratio ok to run a T3 turbo at 10 psi on a stock 1.8L?
Q #2 Will the gtx exhaust manifold work on the 1.8L?
Q #3 Will the stock pistons work without melting with the 9:1 compression ratio?
Q #4 What year RX7 injectors should i use and what size?
Q #5 What is a good stand alone system and could i also get a part number?
Thanks From Dirk Diggler
yes
yes
no, stock BPZE internals are all forged.
I believe the 2nd generation non-turbo RX7 injectors are the ones to get.
megasquirt i guess... it's the new hype... or you could spend some money on an A'PEXI SAFC.
Yes
Yes if it's a 1.8L GTX
If tuned right it will hold 15-20psi, if tuned bad will blow at 5psi
2nd gen non turbo or turboII (turbo II you need to check to make sure the impedance is right
SDS, Haltech, F.A.S.T, Electomotive, Motech
It's not that big, so don't act like it is.
Jeffescortlx said:
It's all in the tune. As long as you keep it from going lean, you wont melt any thing.
10psi will make a lot of power with 9:1.
Ok I was thinking, lets take me for example...I am getting a custom tuned chip on a dyno at a shop 50 miles away form me. I wont be able to do any tuning by my self. Now I'm thinking..do I really even need a a/f gauge? I just read EVERYWHERE that the two gauges that you get are boost and a/f. But if I went lean, there would be nothing that I could do, and its not like I am tuning my engine and need to know the a/f. So what I'm trying to get at is...are a/f gauges all that necessary to a person that is not tuning their car by themselves? I'm just trying to save myself 35 bucks.
Hold the phone on question 2 guys. He said T3 in question 1 so I would assume he has a T3. Now we all know that a T3 will not fit the GTX manifold unless you make some sort of adaptor which would make using the GTX mani a moot point. Might as well make a custom mani. If he doesn't have a turbo we need to steer him to the correct turbo that fits it.
GTX manifold will fit but you need I believe it's either a vj14 or vj20 turbo.
Hmmm.... I kept hearing people on here using vj11's and vj20s or that beastly vj20 Hybrid that Corksport makes... So which ones is it? cause now I'm a bit confused, and I'm not even a newb... I just don't know which turbos bolt up to the GTX/R Manis.
vj-20 bolts up to the gtx mani, as well as the vj-23 if you can find one, and hybrids work as well if your staying with the hot side of the vj-20, Ive heard that vj-14's work also but Im not sure about that cause Ive never done it, and dont have one handy, this is all for the 1.8l gt of course, if you have a 1.9 or a 2.0 escort its a mute point, unless you swap engines
1 - 12 of 12 Posts
