Okay, so my AC didn't work. The compressor wouldn't start, nothing... I spent months trying to figure out what was wrong. Took it to a shop -- they spent two hours, said it was electrical but they needed more time. Didn't have the cash. $160 down the drain -_- I tested the CCRM -- pin 30 or something didn't work, so I found the problem. I ordered a new CCRM off of Ebay, and put it in today.
The car runs fine. Only, now whenever you turn the AC on you can hear everything starting up, but it's still warm. You can hear the freon decompressing when you turn the car off, etc. But the AC still doesn't work... and then there's this. Every ten seconds there will be this "click" noise, the idle will drop and the car will shake. Then it'll be fine -- for another ten seconds. It's coming from the left side of the car, I think, but I'm not sure. I think it's the compressor, as that would make sense -- everything else starting up but no cold air?
So question: does it sound like the compressor? If not, could it be something worse? Could it be the CCRM, or could the compressor be bad?
