New car weird issues. | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by gastroker, Jun 12, 2011.
  1. gastroker
    gastroker New Member
    16
    I got a 91 escort gt with a blown motor several months back and have just got around to pulling and replacing the motor. The new motor has 70k and had been sitting in a garage for about 2 years. Upon completing the project, i fired the car up and it was knocking and smoking like crazy, thought the motor had a blown head gasket and the bottom end probably need a rebuild. I let it idle up to temperature and the knocking began to quiet down but it was still smoking quiet a bit. I took it around the block and after about 5 minutes or so all the knock had gone and it isn't smoking whatsoever. Just wondering what you guys think this would be caused by? Stuck rings, blocked oil passages maybe....idk.
    Here is a link to how it was running before it cleared up.
    http://www.youtube.com/watch?v=0m2W9tr0jk8
    Anyways im not complaining just curious, New owner of a descent cayman gt :D
    Got this car for 450 bucks with the new motor.
    [​IMG]
  2. 88scortgt
    88scortgt FEOA Member
    750
    166
    Elkhart, IN
    I had the same experience once with a Chrysler 2.2 that sat for a few years. After I put the motor in, it knocked and smoked for about 15 minutes, then ran perfect. I put almost 40,000 miles on that motor before I sold the car and never had a problem with it. I never did figure out what caused it, but after that experience I always made sure to prime the oil pump before starting a motor that has sat for a while.
    You got a good looking GT there for $450!!
  3. gastroker
    16
    It runs like a champ now, not a tick or knock. Just need to get the exhaust re welded.
  4. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    These engines have hydraulic lifters and it just took time for the lash to go away. Probably smoked due to sticky rings or valve guide seals.
