Need to replace stock turbo.... | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by SpeedMafia, Apr 9, 2020.
  1. SpeedMafia
    SpeedMafia FEOA Member
    300
    96
    178
    Denver Colorado
    My 85 gt turbo went out its blowing oil...what turbo should I replace it with I want a ball bearing turbo but same size but I dont know whata on it now...need help. Thanks guys
    ricksgt likes this.
  2. austin86
    809
    274
    78
    Ohio
    stock manifold? have you thought about a rebuild kit?
    ricksgt, zzyzzx and SpeedMafia like this.
  3. SpeedMafia
    300
    96
    178
    Denver Colorado
    Yes stock manifold but I dont want a bushing turbo if I'm going to replace it I believe a ball bearing turbo would be nice
    ricksgt likes this.
  4. 1982 EXPert
    1982 EXPert FEOA Member
    114
    92
    38
    Stock is an IHI RHB5 VC31 8304
    There's a lot of "compatible" IHIs out there but they're not usually the right configuration between physical dimensions and compressor/turbine wheel combos. I have a chart on them somewhere.....
    But most are no longer available and I don't think any are ball bearing.
    I'm also after a similar-sized ball bearing turbo for my 1.9 Turbo, it's a brand new motor that was build ground-up completely from NOS parts - even the turbocharger!! But I want to replace the stock manifold and stock turbo setup with something better flowing of my own design and a more common turbo with modern construction (with ball bearings) so it's more reliable and easier to source. So eventually I'll be selling my NOS turbo, manifold, and a few other goodies.
    Anyhow, since I have 2 stock turbo manifolds I will be modifying the ugliest one to work with a more modern turbo (probably T3 style) because the biggest issue with the stock manifold is it really only fits the 1 stock turbo :/
    That's something you might have to consider unless you're fine with a Euro Escort RS Turbo (T3 style) or an aftermarket setup.
    ricksgt, SpeedMafia and austin86 like this.
  5. SpeedMafia
    300
    96
    178
    Denver Colorado
    Thank you for spending the time to write this up...yeah I think I need to bite the bullet and have it rebuilt. Uugghhh on well I dont plan on racing it or anything I just want a clean 85 gt turbo and keep it as stick as possible but would like to go ball bearing but oh well I'll look to see what it will cost to rebuild lol...uugghh
  6. 1982 EXPert
    114
    92
    38
  7. SpeedMafia
    300
    96
    178
    Denver Colorado
    Will this work? need to rebuild my turbo... seems it should be right?
    ricksgt and zzyzzx like this.
  8. ricksgt
    ricksgt MY 1989 Ford Escort Terlingua GT .
    613
    151
    193
    Biloxi ,Mississippi.
    :thumbsup::D;):)
    Joey_Twowagons and SpeedMafia like this.
  9. ricksgt
    613
    151
    193
  10. SpeedMafia
    300
    96
    178
    Denver Colorado
    I remember that video he he on a different note , when removing the turbo from this 85 gt turbo so I need to remove the turbo manifold or can I just unbolt it from the manifold and leave it all intact?
