Hey guys I need some more help with my a/c. I just replaced the drier, orifice tube, and cycle switch. I also had the system evac'ed and recharged. My cooling fan is working. But after about 5 minutes of the a/c running it will make a loud noise and pressure will release from the high side line right where the orifice tube is. I turn off the ac right away to keep something from blowing but obviously it is building too much pressure for some reason. What else could be causing thing? Could a bad compressor do this? I am not sure what else to look at. The clutch seems to be kicking in just fine and working fine, there are no strange noises coming from the compressor other than the click when the clutch engages.. My a/c seems to be cool but not ICE cold like I need it to be.
