need help on what to buy for auto-x | Ford Escort Owners Association (FEOA)
Discussion in 'Autocross & Road Racing' started by rangestang, Dec 26, 2011.
  1. rangestang
    rangestang FEOA Member
    427
    26
    So i need some input here guys I have about $300 I can spend the car is a 94 wagon all bone stock the air silencer is removed but other than that all stock. I am wanting to run in the ST class or as close as i can. I was thinking a short shifter, hyperflex kit, ball joints, tie rod ends. Anything else?
  2. Awesome90sSpeedStripe
    Awesome90sSpeedStripe New Member
    48
    Springfield, Mo
    You might be able to sneak in MX-3 LCA's and TTL's for that slightly wider track. I doubt race officials are gonna be able to eyeball the difference, assuming it fits your budget. B&B in Nixa has a pair of MX-3's which most likely have the parts on them.
  3. rangestang
    427
    26
    Is that a pick and pull yard? How much wider is the track?
  4. rangestang
    427
    26
    Has anyone put the zx2 hyper-flex kit on a 91-96 escort? Is the swaybar bushings the only thing that don't fit im getting conflicting info.
  5. Awesome90sSpeedStripe
    48
    Springfield, Mo
    They're not pick 'n pull, but they've been pretty fair with me on prices. If I recall the track is 15mm wider per side, so 30mm total.
  6. rangestang
    427
    26
    Little update guys...the wagon now has coilovers, lowtec struts,polymer full kit,poly engine mounts, zx2 wheels, hankook optimo 195/60/15's, strut bars front and rear, b&m short shifter, 50 giggle gas she rips through the corners!
  7. rangestang
    427
    26
  8. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    The bushings will fit. The rear bushings just have to be reamed to fit your wagon bar. I suggest a Suspension Techniques sway bar kit, if allowed in your class. I have had my set for about 8 years now and I love them. The front adds a 3/4" bar(get a stock GT front bar for max anti-sway) the rear is replaced with a 7/8" bar. If going ST bars, you won't need to deal with the mod to the other bushings.
    [​IMG]
    [​IMG]
    Don't mind the grime, a little low to power wash easily...
  9. rangestang
    427
    26
    I got the bushings to fit just fine bit of a wrestle but I got it done. Any more shots of the bars? Next big mod is prob gonna be a bp. :)
  10. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    Just a couple...
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Those are the original bushing, 8 years and just fine.
    Being 1.8" lower, the center brackets clear by about 3", have scraped twice in 8 years. The only "mod" to fit these is to open the original end link hole in control arm to 5/8". Just needs a quick drilling.
  11. rangestang
    427
    26
    Much better! The only issue I can see is my car is dropped about 4in.
