1 - 4 of 4 Posts
you are refering to the three dash bolts that are in the defroster opening onto of the dash.You should use a u joint adapter for your socket to be able to take them off.
Ok I went out in the dark. I find one in the defroster vent from the inside(of car). Wheres the other 2? I tried to budge it and it still not ready. Are the other two right by the one in the center or soemwhere esle on the dash? ALso What do you mean by stnad outside and use a 10mm and look through and get the dash bolts? Are there bolts under the hood? Or cowl? If so how many thanks....
1 - 4 of 4 Posts
