Mozencrath said:
"Valve seat drop" ??? Would not affect all cylinders.
you bet it can affect all cylinders. you didn't mention any weird noises in your original post here, but in this post:
http://www.feoa.net/modules.php?name=Fo ... ic&t=66733
you mention prior noises, which are certainly an indication of valve seat issues. like madmatt2024 said, the valve seat can be loose, fall down onto the valve, then get popped back in and be fine for a short time. if you hear that noise, that is your warning of imminent failure. once the valve seat breaks, the pieces can get sucked back into the intake, into the other cylinders. I personally have seen this, on at least two different cars. one the guy drove in to my friends shop, on 3 cylinders. when we took the head off, pieces of valve seat had come across from cyl #4 to cyl #3 and #2.
based on the lack of info from you "zomg my car just shut off! what's wrong with it??" we have to go with the obvious solutions first. Thats why we suggested timing belt, they will suddenly fail causing issues like what you described.
