Need 2.0 diesel head gasket | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by Spininwrenches, Mar 15, 2020.
  1. Spininwrenches
    Spininwrenches FEOA Member
    14
    Anyone have any luck sourcing a head gasket for a 85 2.0 diesel?
  2. austin86
    1,063
    347
    118
    Ohio
  3. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,496
    1,164
    Vancouver Island, Canada
    If that indeed is the right parts on Rockauto, order soon, as both are "Wholesaler Closeout".
    The head gasket is $5, the head kit $46, which seems like a bargain.
    However I would compare the images carefully with what you have, as the Mahle and Ajusa gaskets look different.
    Mahle:
    [​IMG]
    $4.68 $0.00 $4.68 Alternate
    [​IMG]
    AJUSA 10030900 {#R20110271G, RF0310271, RF0310271G} Info
    87.5 Bore Diameter; Engine RF
    AJUSA 10030900[​IMG]
    [​IMG]
    Head Set (Recommended) [​IMG]
    MAHLE HS3763 Set Info
    Cylinder Head Bolts Not Included [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 1 Remaining)
    MAHLE HS3763[​IMG]
    [​IMG]
    $45.79 $0.00 $45.79 Alternate
    AJUSA 52067200 {Click Info Button for Alternate/OEM Part NumbersRF1099101, RF1099101A, RF1099101B, RF1099101BN} Info
    Engine RF
    AJUSA 52067200[​IMG]
    [​IMG]
  4. austin86
    1,063
    347
    118
    Ohio
    Knowing Rock Auto there is really no way to know for sure if those photos are accurate. That being sead there is a drop down box to change from "Wholesaler Closeout" to regular inventory.
  5. Spininwrenches
    14
    I was able to track them down in the U.K. the AJUSA 10096200 comes back to a identical match. Rock auto is out of stock of anything that looks correct so I’ll have to wait to get mine from across the pond. Going to order a few if it matches. I plan on doing a mild build down the road when I find another long block to play with. Appreciate the assistance, hard to imagine there is a group for these cars- uglier than sin but fun as hell. I need to start hoarding parts apparently
  6. Spininwrenches
    14
    I believe the difference in part numbers for same gasket are going to be the different thickness needed for piston protrusion, might order one of each since spacers are harder to locate than the gasket. Also found a guy that claims to have the kits as well as injector and pump reseal kits so things are looking up
    zzyzzx and austin86 like this.
  7. Spininwrenches
    14
    I sourced a complete engine gasket kit with head bolts from Australia- OEM Took forever to get here with the covid shutdowns but now I need head torque specs..... now I can’t find a repair manual that includes the Diesel engines. I had 3 of them at one time and tossed when I tossed out my wagon. Anyone able to help
  8. Joey_Twowagons
    2,496
    1,164
    Do the diesels use the disposable Torque to yield bolts?
  9. Richard Forshey
    Richard Forshey New Member
    do you have a link to that headgasket you found in Australia? Thanks in advance
  10. Richard Forshey
    Tighten bolts to 30 N-m(22 lb-ft)
  11. Spininwrenches
    14
    This is the email I have for the guy- however I can’t find the website. Email the guy and ask for webpage.
    [email protected]
  12. Spininwrenches
    14
    lmao- a whole 22ftlbs you say. Finger tight it is
