Hello everyone and thanks in advance for any help you've got. I've got 94 Escort Wagon with a 1.9 EDIS in it. The car starts right up, no problem, if the car is cold or if it is turned off and back on within a few minutes. Once the car warms up it will just die out of the blue. what I've figured out so far I can drive the car on very short trips (about a mile) in traffic but if I keep air flowing over the engine it will stay just cool enough to run but if I have to stop at 2 long stop lights its gonna die and it wont start back up for 15-30 minutes. It is so temperature sensitive that a hot day will shorten its range to about 4 blocks and on a cool night I can go about 5 miles.
I've spent 2 days searching the forums here and have come close but I'm not exactly sure of where to start.
The car is throwing a 211 code which according to Haynes is a Profile Ignition Pickup (PIP) circuit fault. That is the only place in the whole book that mentions the PIP. As far as I can find here the PIP comes from the TFI but I can only find the TFI connected to a distributer, which my car doesn't have. So I need to know if the EDIS ignition module replaced the TFI (Ignition Control Module). See the TFI thing had me going because everyone said they were heat sensitive. Is the EDIS heat sensitive also or does anyone have any ideas. There are no vacuum leaks that I can find.
Another sign that may help with diagnosis is that after about a 1 second delay after the car dies I can hear the fuel pump and EEC power relays click off. When I turn the key both relays work but the car will not start until it fully cools down.
As I said I've searched every post I could find. I couldn't have gotten this far if it weren't for black93scort's post "Acronyms Explained", it's been open on my desktop for 3 days now, thanks a lot, great job. Also UnexplodedCows posts really helped me get on the right track.
If you have any advice or have had the same problem, your help would be much appriciated.
Thanks Again
Snags
Thanks Again
Snags
