my escort does not turn on! :S | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by chinoRR, Mar 31, 2013.
  1. chinoRR
    chinoRR FEOA Member
    17
    11
    good night i have a problem with my car and i was wondering if someone can help me,, i arrived to my house as 3 hours ago and i turned the car off,, but now when i wanted to move my car,, it did not turn on! :S i do not why,, there arent others problems with the car
    what do you think?? thanks a lots for yours answers!
  2. kuwacs
    kuwacs FEOA Member
    130
    176
    Need more information.
    When you turn the key on, what happens? And noises, lights, or any signs of action? Is there any clicking?
    Usually when you turn they key to the ON position, you'll hear the fuel pump prime (a little whurring noise) in the back. Do you hear that?
    Also, with the key in the ON position (dash lights should be on), check if you have a light that says "Fuel Cut-off" lit up on your dash.
  3. denisond3
    10,127
    2,830
    Is it an Escort with the automatic transmission? Or does it have the 5-speed transmission?
    You should be able to turn on the headlights - and have them come on. Then turn on the ignition and have the small lights at the bottom of the instrument cluster come on. I mention doing this because the headlights use a different fused circuit than all of the rest of the things in the car. If the headlamps DONT come on - I would suspect a bad battery cable or connection. If the headlamps DO come on, I would suspect a bad ignition switch; because they are known to give grief -eventually-.
    Also there are the interlocks to prevent the starter from cranking - and they are different for the automatic transmission versus the 5-speed transmission Escorts.
