Uhm... did someone fail Elementary school? Let's start by making this a coherent post.
greg91gt said:
Every time I start it, it revs up and then dies. Or, it will start then will just die. When I give it gas, it dies down and when I drive it, the motor revs up even if I do not give it gas.
First of all, this is posted in the 3rd gen section so I am going to assume you have a 2.0 SPI, not a 91 EGT as your name suggests.
Here are a couple ideas, I will think of more once I wake up.
- Check and clean MAF sensor.
- Check and clean IAC valve.
- Visually inspect for vacuum leaks and use a vacuum gauge (MityVac) to test
