101 - 120 of 144 Posts
Discussion Starter · #101 ·
I had to make some modifications to make the idler puller fit but it works :D Bumper Gas Automotive exterior Automotive tire Cameras & optics
Gas Bicycle part Bumper Metal Auto part
Automotive exterior Tints and shades Vehicle door Auto part Electric blue
Motor vehicle Gas Automotive fuel system Auto part Machine
Automotive tire Motor vehicle Automotive engine gasket Gas Engineering
Discussion Starter · #102 ·
Engine is officially ready for drop in. Now I need to assemble the transmission... Automotive tire Tire Motor vehicle Vehicle Rim
Motor vehicle Vehicle Automotive tire Hood Automotive design
Motor vehicle Automotive exterior Gas Auto part Vehicle
Automotive air manifold Automotive fuel system Gas Motor vehicle Auto part
Discussion Starter · #103 ·
So I ran into a snag, the tranny is seized so I have to pull the motor/tranny out and try to reassemble it correctly
Discussion Starter · #104 ·
Finally got the tranny apart and discovered that I have cracked 5th gear synchros. I also found out that the 1.9 and zetec 5th gear doesn't swap in but the zetec synchros do fit. Unfortunately I only have one good one. Now I have to order some :(
1998 ZX2
I don't think a cracked synchro ring should cause the tranny to lock up. However, installing the 5th gear synchronizer assembly backwards probably would and its an easy mistake to make if it comes out of the shift fork. Almost made this mistake swapping 5th gear on my dads ZX2, it came out and I had no idea which way it went back in, had to find a picture online to reference.
I have a complete 5th gear synchronizer assembly from an SPI/Zetec transmission if you could use parts from it.
Discussion Starter · #106 ·
The lock nut wont thread on the shaft with 5th gear clutch hub backwards. I replaced the synchros and it works fine now.
Discussion Starter · #107 ·
So I got everything in and now I can't get the fuel pump circuit to energize :( anybody have a circuit diagram of the fuel pump/relay/inertia switch?
1998 ZX2
Here is one for a 93 GT
  • Like
Reactions: pnmred
Discussion Starter · #109 ·
Thank you. I have verified that the circuit is energized in the "start" position but not in the key on engine off condition. The factory service manual says the circuit should energize when in the "run/on" position but it wouldn't be the first error I have found in the manual.
1998 ZX2
Typically on cars, the fuel pump only energizes for a few seconds in the key on engine off position, not the whole time.
Discussion Starter · #111 ·
Yup that's why I initially thought something was wrong. The bp fuel pump is energized during start up and when the key is in the "run" position AND the VAF switch is closed. Thanks for the diagram.
Discussion Starter · #112 ·
I'm sure it's written somewhere on the forum but I Just realized this.
Door Wood Household hardware Gas Handle
1998 ZX2
Yep, F-series and G-series transmissions have a different shift linkage.
Discussion Starter · #114 ·
I fabbed up this exhaust from a magnaflow cat and bosal exhaust for the 1.9
  • Like
Reactions: Escort LXR
Discussion Starter · #115 ·
It's running, it's driving, it's glorious.
  • Like
Customizer
HAHA! Another Escort Back on the Street is always good to hear; Especially if it's a Wagon with a 1.8L BP!
Can't wait to get mine back up and running....
Discussion Starter · #118 ·
1993 mazda BP. I need help figuring out why my ignition control module keeps failing. The original '93 ICM lasted over a month with no thermal paste. Swapped in a ICM from a '94 with no thermal paste and it lasted about 5-10min. Swapped in a new ICM from parts store, used thermal paste and it lasted about 20 minutes.tried 2 different coils, both are within spec range. What is going on?
Discussion Starter · #120 ·
Bad distributor sensor.
