1 - 10 of 10 Posts
The MX3 is the same chassis as the Escorts and the 1st gen Protege. We both have the same 4x100 bolt pattern and the struts/hubs are the same.
The seats bolt up also because of the chassis issue.
Almost eveything off an MX3 can be bolted up or made to fit very easily. There are a few things that are different between the 2....but not a lot.
Just watch the offset on the rims.
If they are meant for an MX-3, then there shouldn't be an issue.
But if they are over a 45mm offset then you'll need spacers and if they are under 35mm....keep looking.
1 - 10 of 10 Posts
