Hi!
I am having very rough running/bucking problems with my 99 Escort/SOHC. Had it scanned at a local shop, they say "Multiple cylinder misfire". No code number.
I swapped out a coil pack from a friend & no change, if anything it is actually worse. The plugs look very good. A google search for the problem turned up a Crankshaft Position sensor as possibly the culprit.
Where to go from here? What other tests should I perform before spending money on parts that I don't need?
Thanks!
Thanks!
