1 - 8 of 8 Posts
whats up guys i got a 94 escort gt got like 75k on it .. so first wierd problem , when started in cold makes a wierd whirling noise but once warm its fine and if i rev it when cold its ok ...a few weeks back i seafoamed it and it went away and was fine .. now it came back ... any ideas ?
2nd wierd thing i fill it with coolant and randomly like a couple months or a couple days numorous occasions it pukes it out of overflow hose dont make sense im thinking thermostat ? anyone have this problem
3rd problem .. when im cruising at low speed like 35 40 in 4th it looses power at random so i downshift in 2 ( or else it wont go ) than random itll spin the wheels and pick up like nothings wrong .
there are a couple other funky moody things but these 3 are most messing wiht me
ps car has new .. watep pump , timing belt , dizzy , clutch , gaskets , VICS and fuel pressure regulator sensors ( those mitsubishi sensors) . and i did that fuel pump trick with hose . timing is advanced also
thanks alot any info at all is greatly appreciated
might be your headgasket. best way to test would be to check for hydrocarbons in the coolant with the blue liquid stuff, cause it sounds like it's intermittent.
thanks guys , so just for hahas im going to change out the cap and rotor , as for the blue stuff you were talking about how does that work ?
oh also i have an intake , doesnt leak but theres no black box in it anymore just a hose to idle valve . someone told me that box gave more torque and was better for car is this true ? thanks alot gus
1 - 8 of 8 Posts
