Moisture under my floor mats | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by gnx547, May 6, 2013.
  1. gnx547
    gnx547 FEOA Member
    428
    168
    The front passenger side of my 96 Escort is always lightly wet under the rubber floor mat. Its not coolant and does not smell like it. The driver side is also like that but as much as the passenger side. Any ideas why the passenger side is always wet under the floor mat?
  2. EscorGo
    EscorGo FEOA Donator
    3,006
    139
    213
    Wichita, KS
    Have you been using the A/C? The firewall drain could be plugged and spilling back onto the floor.
  3. gnx547
    gnx547 FEOA Member
    428
    168
    My Escort does not have factory AC, would there still be a drain?
  4. EscorGo
    3,006
    139
    213
    Wichita, KS
    probably. It's easier to build cars the same. i don't know if water would get in there or condense w/o A/C. It was a thought.
    There are also some cover plates in the floor. Mine were almost rusted thru so i just 'glassed over the holes. You may just have to pull the carpet and inspect.
  5. gnx547
    gnx547 FEOA Member
    428
    168
    I did find the drain and I poke a screwdriver in and out. It does not seem clogged up.
  6. TrunkMonkey
    TrunkMonkey FEOA Member
    117
    14
    28
    Could be the door seals leaking.
  7. 2doorLX
    2doorLX FEOA Member
    51
    158
    St Louis, MO
    It could be the windshield leaking as well.
  8. zzyzzx
    15,177
    1,223
    You have water coming in where the HVAC intake is. You need to open the hood, remove the covers on both ends and clean them out. Once you pop open the hood and see where water running off your windshield would go, that should tell you where to clean. You have a small compost heap on both sides of the car there.
  9. Intuit
    Intuit FEOA Member
    7,556
    934
    Southwest Ohio
