1 - 10 of 10 Posts
I have been having some transmission problems lately, mainly with it not wanting to go into gear. Sometimes it would work if I went all the way to L. Once it went into gear, the car drive and shifted fine. That was 2 weeks ago, and yes I haven't driven the car since then. If it matters, it's a 1995LX with 180,000 miles on it, and an original ATX (TX variety). Anyway, I did a lot of reading on the internet, and my reading told me to check the kickdown cable and linkage and fluid. The fluid level is fine (actually overfilled a bit, but nothing major). When I was looking at the linkage bolt, I happened to stare down at the front transmission mount when I noticed that it was not even bolted up to the car. So I need to get one of these bolts. Anyone happen to know the specs on it? Of should I just replace the whole mount? It looks like The bolt that goes between the transmission and the mount. The mount is bolted to the car just fine.
If you still need this let me know? I am going to the junkyard this week. I can pick you one up no problem.
Discussion Starter · #10 ·
I ended up using a hardware store bolt. M12 x 90mm, along with two hardened washers and a hardened lock washer and hardened nut. The only hard part was breaking loose the two bolts on the bottom of the mount that were original. I had to remove them to get the bolt to align.
1 - 10 of 10 Posts
