1 - 6 of 6 Posts
anybody fit any other style mirrors onto the 2g egts? also ive seen a escort with a 323 front on it any ideas how much it is to switch id like more of a mazda look
YEAH!
Some people have custome fit m3 form civic.
you can run 1st gen protege the are a direct bolt up!
i am running 3rd gen painted to match mirriors. have to drill 2 new holes, and rewire! mine were wired for me!
BYO Plastic cutlery
I was just going to suggest 3rd gen mirrors.
Alien, do you have pics of that? I always figured they were a direct OEM fit because the 3rd gen wagon didn't get any changes from 2nd gen in the windshield, A pillar, doors, etc.
What about a 3rd gen dashboard?
yeah!
i will get pics hopefully soon, since the car will be going buybye next week for a month or so!
i will try and find some.
but you have to drill 2 more holes, 3rd gen mirriors have 4 screw mounts to the 2nd gen 3 holes, the top 2 match the loweer 2 you have to drill. plus change the wiring! the plugs were diffretn!
dash should fit, since the stucture of the car is the same, just your vent tubes are a littel diffretn i would think! plus the door panles, where the dash comes to the doors, might have to do a littel custome work there!
For M3 Mirrors.
The nice this is that the base plate is a bolt-on piece. so that means that the mirrors itself is the same for eveyone...it's only the base plate that changes.
So all you have to do is unscrew the old base plate, and either modify it to fit...or just get a piece of plexi or lexan and make a new one.
sorry for raising an old tread.
when i compare the EGT (90-96) to the BG protege (90-94) the "triangle" is much much bigger on the EGT mirrors. is this an issue? i noticed that the bolt patterns are identical. But my major concern is exposing a part of the door that wasn't meant to be exposed.
1 - 6 of 6 Posts
