there is a drain plug already, but no one has ever drilled the case, at least not in the vehicle. i believe there are 2 options, 22 and 23 tooth, I cant remember which is for at/mt. any local parts store can get one.
First, order a replacement from RockAuto. when it arrives, remove the retainer from the vss, and grab it as necessary with a vise grips. Make sure to twist as you lift. Once it's out, make sure to count the teeth on both the old and the new gears. If they don't match, swap the gear from the old to the new. Smear a little atf on the sleeve of the new one and install. Problem solved.OK now this is kind of strange but,may help me or others. I have a 1995 escort 1.9 5 speed,can't get the speedometer drive our to check or fill the transmission. This seems to be a common problem. Here's where it gets weird,back in the 80s/90s Audi decided their differentials didn't need to be drained or filled(sealed unit) then someone figured out that was a great theory but not a real world good Idea,so they put out a bulletin on where to drill and tap assembled differentials for drain and fill plugs. Does anyone have a case apart to see where we could drill and tap for fill plugs on the escorts? Okay,if not does anyone know how to determine which speedometer drive I need to have on hand for when mine gets destroyed on removal?
As a parts guy for 40+ yrs -- THANK YOU THANK YOU THANK YOU .Thank you all,done,all is good. Just to throw this in there I've worked on Automotive for decades,owned a parts store. Worked dealer service and parts,aftermarket service and parts. I will not buy two parts knowing I will return one,I will not a part and return it because it didn't fix my problem. It is a pain in the @$$ to the parts dept. and costs the company money.
