Manual Rack Swap guys HELP!!!! | Ford Escort Owners Association (FEOA)
Discussion in 'Suspension' started by Roboskittle, Jan 9, 2007.
  1. Roboskittle
    Roboskittle New Member
    386
    Little Rock, Arkansas
    Ok I have the manual rack already and am ready to install it. The problem I am having is this. The Manual Rack input shaft has a spline shaft on it that looks like a start with ass loads of points. The rack I pulled out of my car had a totally different looking shaft so it will not hook up to my Steering column. I will get pics today of what I am talking about and post them that way you are clear but what I need to know is when you swapped out racks did you pull something else off of the donor car that was connected to the rack???? Thank you.
  2. therieldeal
    therieldeal FEOA Member
    8,622
    19
    338
    Northeast CT
    i think you're gonna need the u-joint from an escort pony
    -jon
  3. Roboskittle
    386
    Yeah Im thinking the same thing. If I had pulled mine out of a car that would be no problem.
  4. therieldeal
    8,622
    19
    338
    Northeast CT
    i'd toss something up in the junkyard watch forum, thats a pretty small/quick/easy part for someone to grab
    -jon
  5. Roboskittle
    386
    Here are the pictures.
    [​IMG]
    Ok the piece on the right is what the old power steering rack that came out of my GT had. The piece on the left is what I need the part to have.
    [​IMG] This is the upper shaft on the part that comes on the escort and is the correct upper shaft for the part I need. The part that I pulled in the picture above came off of a 323 and has the wrong upper shaft and will not work.
    [​IMG] This is overall what the part looks like as a whole with the upper shaft on the left and the universal joint on the bottom.
  6. Fernie_Boy
    Fernie_Boy FEOA Member
    111
    166
    Laval, Qc, Canada
    does anyone knoew anywere else that we could find that steering coupler ( U-joint ) ???
    I cannot find any escort pony around here, it makes a while that those disapeared off our road because of massive rust, even regular 2nd gen are really really hard to find in decent condition
    can anyone help me point out a junkyard that might have one or any other solutions??
    I also need my car running for june 11th!!! so I need it fast...
