manual rack for 1.9L | Ford Escort Owners Association (FEOA)
Discussion in 'Suspension' started by silverton, Jan 2, 2007.
  1. silverton
    silverton FEOA Member
    2,719
    288
    Seattle, WA
    is there a way to depower the 1.9L steering rack or do a conversion? I am just curious if someone has already done it and how much of a PITA it is...
  2. Roboskittle
    Roboskittle New Member
    386
    Little Rock, Arkansas
    Go to Autozone and you can buy a brand new manual rack for your car for 125 bucks. Good luck finding a pony in the junkyard so you can find the end part of the steering column so you can use it though. That is the problem I am dealing with now. As far as depowering I tried on my GT and I cannot figure it out. Its not the same set up as the Miata Rack. Dont know the difference between the two racks but Autozone lists two different part numbers between LX and GT.
  3. jfarcas
    jfarcas FEOA Member
    567
    166
    Athens, OH U.S.A.
    You can also re-route the fluid lines back into each other, and remove everything else. This way, you don't have to remove the rack at all. I haven't done it personally, but I've heard it works well.
  4. ryanrules
    ryanrules FEOA Member
    5,209
    338
    Pennsylvania
    or swap the rack out of an escort pony. all of the pony racks were manual steering.
  5. silverton
    2,719
    288
    Seattle, WA
    if autozone has the manual rack, shouldn't they have the peice to connect it as well? the redundancy of autozone amazes me
  6. jfarcas
    jfarcas FEOA Member
    567
    166
    Athens, OH U.S.A.
    They don't stock that part most likely because it's not a piece that really ever needs replaced, that is, it doesn't need maintenance, so most aftermarket companies won't bother manufacturing it.
    While we're on the topic of the manual rack - anyone know whether or not the bushings are the same for manual and power racks? I'm thinking of buying the poly bushing set, but I've heard that the bushings included in it are applicable to the power steering, not the manual rack.
  7. escortrio
    escortrio FEOA Donator
    890
    7
    268
    st. louis, mo
    would you say its hard to swap with the engine & tranny still in there?
  8. escortrio
    890
    7
    268
    st. louis, mo
    if i go to autozone and buy a manual rack-n-pinion would there be anything else i would need?
    would the steering wheel automatically turn 2 times instead of 3 like it should?
    im gonna pull the tranny out so im gonna do that while im in there, its what i really want.
  9. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    DO NOT DO THIS!!! Routing the lines back to itself does not make a manual rack. It makes a malfuntioning power rack. It will get increasingly harder to turn, and at some point, will fail. If it results in an accident, and your insurance company finds that you have done this... your screwed.
    I don't know why people think this is an acceptable alternative to a manual rack. It is not.
  10. Dave94LX
    5,787
    238
    Under the Stairs
    not all pony's have manual racks. There were a few options for the pony, such as PS, rear defroster, and radio. The junk yard that I frequent has about 10 pony's, and I would say 6-7 of them have power racks.
    BTW, if you swap a manual rack, you will either need to get a pony accessory arm with dummy pulley, make your own dummy pulley, or relocate your alternator, so that the serp belt doesn't lay on top of itself.
  11. escortrio
    890
    7
    268
    st. louis, mo
    thats one thing im really wondering since its so rare to find a pony at a yard to get that idler pulley
    that and doing the aligning on it like it says since i'll be putting one on that was never alligned in the first place. i think i just need to go do it instead of thinkin about it it'd just suck to mess up the steering wheel and do some unexpected of roading
    iv had a pony and turning that vs a power one with out it on is just not the same. soooo not worth it.
