I have 2000 escort zx2, it has a 2.0 zetec dohc with a manual tranny. I recently had to swap the engine, I found a good replacment at a local junkyard it came out of a 2000 zx2, the only difference in the 2 cars is the junkyard moter came out of a car with an auto trans. the only difference that I could see between the 2 engines is the crank sensors are positioned a little differently. I did the swap and now the moter won't start could the positioning difference of the crank sensor :? be the cause?
