good afternoon: i have this tiki tiki tiki sound only at idle.
when i start the car from cold the sound doesn´t come out, but when the car are warn that the temp pass the little box in the gage the car start to make that noise.
the weird thing is that when you push the pedal the sound disapears so when you drive hard or normal tha motor sound are good, but when you put the car on idle the tiki sounds return
i can heard the sound on the oil pan, in the crankcase not in the head (lifter or inyector)
i put a bottle of CD2 detergent and the sound still the same
last month i was using mobil 1 (5w30) and the sound start, so i put ELF MOLYGRAF 15W50 and the sound decrease a little bit but still there only when the car are warm.
another question can i change the rods and maybe the main bearing without taking out the motor???? and the tranny?????
i´m looking for a cheap remedy because i want to buy a ZX2 escort.
please any advise????
