Well, I cut the grass a few days later... Now, less than a week afterwards, their are three times as many dandelions and it's just as tall as before.
The news keeps saying that there is a "Fire danger due to dry conditions in my area." My grass and plants say otherwise.
I got the stuff for fixing the A/C ordered last week, It came in yesterday and hopefully I'll get it installed and recharged today or tomorrow. Also, despite what H&R says, you need to cut your front bump stops to run these springs. After I got the front installed the car felt really stiff and would squeak if you bounced the front. After looking and doing some measurements it became obvious that the front was just touching the bump-stops while sitting on level ground. The ones I installed were the same length but about 1/3 thicker compaired to the OE ones which didn't help much. I ended up cutting 1" off them both and it rides much better now. Definitely stiffer than stock but not uncomfortable. The Motorcraft struts seem to handle the springs well, the car doesn't feel bouncy and if you bounce the suspension in the driveway it basically stops as soon as you let go.
I also got the rest of the sound system installed. I got the 8 gauge power wire and RCAs ran. I used the factory amp connector under the drivers seat for the remote turn on signal and to power all of the speakers. My tweeter pods also fit great.
Here is the aforementioned filler pipe from a few posts ago. Somehow, this didn't leak when I smoke checked the EVAP system. The seal for the plastic piece must be farther down.
I also discoved after washing the car that at least one of my trunk leaks was caused by the rubber seal on the plastic piece that goes around the filler neck behind the gas door no longer sealing against the car body. I put a nice bead of RTV on that part and reinstalled it. Hopefully no more leaks.
