LX-E's auto seatbelts? | Ford Escort Owners Association (FEOA)
Discussion in 'Interior Modifications' started by cheap-escort-CAN, Oct 20, 2010.
  1. cheap-escort-CAN
    cheap-escort-CAN FEOA Member
    305
    168
    Vancouver,Canada
    I thought I have read this somewhere but can’t remember for sure so I will ask. Do all LX-E’s come with auto seatbelts? Thanks for your time.
  2. denisond3
    9,956
    2,716
    I have heard the Canadian modesl came with manual seat belts, the USA versions with the auto belts. Those of us with no-longer-working auto belts envy the Candian design.
  3. cheap-escort-CAN
    305
    168
    Vancouver,Canada
    thank you for the info I just bought an LX-E and that was one of the major sticking points with me is the seatbelts iam assuming its from the states as it is the first lxe I have seen on the west coast of Canada and it does have the auto seatbelts and I already cannot stand them !!!! Thanks again
  4. denisond3
    9,956
    2,716
    With my 92 Escort the auto seat belts still work fine, and its handy to be able to hop in the car and drive off - without putting on the lap belt - and being confident I wont get a ticket, since the shoulder belt is visibly 'up'.
    The I got my 91 Escort. Its driver side belt was sticking. I took it apart, lubed it, and it worked great until the cool weather of autumn. So I moved the shoulder belt anchor to the underway position and unplugged its connector. I just have to rememober to put on both belts when using that car. I would be glad to get a good auto-belt assembly from a JY, but most of them are missing already.
    I have gotten used to the auto-belt and dont mind itl but would switch to the Candian style belt if I happened onto one. (Actually I need 3, having 3 2nd generation Escorts).
    If you go after a set in a BC junkyard, be sure to get the interior trim pieces too, since they will be different.
  5. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    i know i said this before but in mine, the only time i have a problem with the seat belt is when the ignition switch is failing.
  6. cheap-escort-CAN
    305
    168
    Vancouver,Canada
    I will more than likely switch them out for manual belts it’s probably just a matter of time before they start to act up. Thanks for the help!
  7. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    another thing to watch when the ignition switch starts to go is the brake light and fuel cut-off light on the dash. they will fade in and out, or will stay on at the same time with the engine running
  8. cheap-escort-CAN
    305
    168
    Vancouver,Canada
    So I was wondering if I could swap the mx3 1 pc seat into the lx-e (being 6' 5'' and all) and because of the auto seatbelts will there need to be a relocation of the "power box" that’s under the driver seat? Thanks for the input
  9. cheap-escort-CAN
    305
    168
    Vancouver,Canada
    also 4dr, auto if that makes a diff
  10. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    i don't think it will be any issue
  11. cheap-escort-CAN
    305
    168
    Vancouver,Canada
    cool beans. thank you muchllly
