Low fuel light? | Ford Escort Owners Association (FEOA)
Low fuel light?
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by kln5014, Oct 16, 2006.
  1. kln5014
    kln5014 Guest
    40
    Never had the nerve to find out if my escort has a low fuel light, does a 91 Escort have a low fuel light? Just a ponder...
  2. ryanrules
    ryanrules FEOA Member
    5,209
    338
    Pennsylvania
    no
    91-03 escorts are 4x100 pattern. the earlier ones are something else
  3. ryanrules
    5,209
    338
    Pennsylvania
    dood. you totally made me look like a noob
  4. JohnnyBee
    JohnnyBee Guest
    1,828
    theres no fuel light
  5. kln5014
    kln5014 Guest
    40
    haha sorry about that ryanrules...i asked that question and then found the answer elsewhere, and since i was wondering about the light anyway, i changed it to that
  6. kln5014
    kln5014 Guest
    40
    while we are sort of on the topic of wheels, would ZX2 wheels fit as well or are they different?
  7. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    ^^ yes.^^
  8. highanddry
    highanddry Guest
    8,446
    5
    The correct answer to the question about the low fuel light is: it depends on the trim package you've got (Johnny B is from Quebec, so he doesn't have a clue :eek: ).
    My old 91 LX with the sport cluster had the low fuel light.
    My new 91 LX without the sport cluster did not have the low fuel light. After doing the cluster swap, it now does :D . I love that light. The cluster swap also gives you a tach (once you're run the tach wire and changed the EDIS module) and a fifth cluster backlight. Then I added cruise control, changed the steering wheel cover and it's like I'm driving my old car, minus all the rust!
  9. scortLX95
    scortLX95 Guest
    7
    also to see if you have a light or not when you first put your car to the run postion all of your "dummy lights" light up .
  10. kln5014
    kln5014 Guest
    40
    wouldnt want to do a how-to on that cluster swap would you? i have been dying to get a tach on mine
  11. bluefoton
    bluefoton Guest
    223
    Haha Quebec here too... See, we don't need idiot lights :) Our rule of thumb is start the engine, and if the fuel gauge turns to the LEFT even ahead of "E", it's time to add gas. We also mix it with snow, it improves tachyon particle atomization required for starting the car at - 198F.
  12. pyro_maniac69
    pyro_maniac69 Guest
    749
  13. Angdvl089
    Angdvl089 New Member
    1,027
    Massachusetts
    Do you know if an EDIS from a gt will work with an LX?
  14. InuYasha86000
    InuYasha86000 Guest
    40
    I actually want to put in a higher speed reading spedo in my escort, the stock highest reading on it is 140km/h but i've seen ones wich go about 160 or 180km/h. any how-to's or things to watch out for?
