Got a 93' LX 1.9L with an interesting idle problem, and I also just failed emissions for high NOx, really high actually like 3-4 times the limit. I think the idle problem may be related to the high NOx and was curious to see if anyone here has had simliar issues. This forum has always been a huge help.
With the idle, when I come to a stop after driving it will hold steady at 900rpm for 10-15 seconds and then will start to lope and droop pretty hard. It will go rapidly from like 400-700 rpm and I end up having to keep my foot on the throttle while out of gear to manually hold the idle up or it seems like it will stall- it has stalled a few times where I don't use the throttle to hold it.
Some older posts suggested that the EGR might be the problem and to test by unplugging the DPFE sensor. I found that unplugging it made the idle stay smooth for longer when stopped, but eventually the loping would come back- but it wouldn't drop as far as when the DPFE is plugged in and it had a kind of steadier 600-800 rpm lope.
I found one post from 2016 mentioning the same problem and said the reason the loping only happens after a delay while stopped is because if the EGR valve is stuck, the idle lope won't show up until the exhaust gas is diluted from not moving for a while.
I'm gonna do all the normal checks like for vacuum leaks, clean out the EGR tube and check it for operation, check the O2 sensor, and whether the Cat is hotter on the outlet than the inlet, but has anyone else had EGR problems that lead to the same symptoms, and success fixing it? If the EGR really is the most likely problem I can focus there first and hopefully save some time.
