Loose timing belt | Ford Escort Owners Association (FEOA)
Loose timing belt
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by Boyce Rampey, Sep 13, 2018.
  1. Boyce Rampey
    Boyce Rampey FEOA Member
    22
    4
    13
    Long story...my timing belt tensioner bearing failed after only 25000 miles. So I installed a new tensioner only. The belt is tight, but after a short drive, I find the belt very loose. Problem has gotten progressively worse. Now I can redo the belt and timing, reset the tensioner, start the engine and it will be loose after running 10 seconds. I tried another new tensioner with same result. What gives?
  2. Gamer92
    Gamer92 FEOA Donator
    3,435
    980
    263
    Southern Indiana
    What brand of tensioner are you using?
  3. Boyce Rampey
    22
    4
    13
    First was from advance, GMD I think, latest one is from NAPA, it is a Gates..
  4. Gamer92
    3,435
    980
    263
    Southern Indiana
    Do the timing marks line up when it gets loose?
  5. Boyce Rampey
    22
    4
    13
    It did actually jump time once. But I have driven a total of maybe 80 miles with it super loose and it has stayed in time. But, I don't think I can continue to temp fate.
  6. Gamer92
    3,435
    980
    263
    Southern Indiana
    Some members here have switched to the 2nd gen tensioner. You could try that. You’ll need the 2nd gen water pump too. You’ll need a newer second gen pump though. I think the older early ones had a different tooth design or something
  7. denisond3
    9,934
    2,699
    The tooth design was only different for the very early 2nd gen Escorts - like they made in 1990 for the 1991 production model. The belt had squared off teeth, so had sprocket teeth to match - i.e. the crankshaft driving sprocket, the water pump and the camshaft sprockets. The change was in early 1991, like as of April 1st I think. After that the Escorts all used a belt with rounded teeth, and the three sprockets to match.
    I dont know anything about 3rd gen tensioners though.
  8. pextor
    pextor Moderator Staff Member
    5,858
    753
    Lancaster, pa
    When my tensioner was loose in my 99 sedan, this is what it sounded like:
    We put a new tensioner on it and it was fine afterwards. It might have been a junkyard tensioner, I can't remember.
  9. DC Ultra
    DC Ultra FEOA Donator
    414
    68
    178
    Bad belt? U didn't change the belt, yea?
