Lightweight bucket seats for first gen? | Ford Escort Owners Association (FEOA)
Discussion in 'Interior Modifications' started by Jade Flacon, Jul 2, 2018.
  1. Jade Flacon
    Jade Flacon Guest
    i do not want to be associated with drugs illegal activity or porn.
    I will be removing all most posts and will no longer post here.
  2. novanutcase
    novanutcase FEOA Member
    2,317
    536
    263
    The only seats I know of that will bolt in are MX3 seats. Aftermarket ebay buckets should fit with a universal mount without much modification.
    John
    Jade Flacon likes this.
  3. Jade Flacon
    Jade Flacon Guest
  4. novanutcase
    2,317
    536
    263
    '92 - '93
    They look like this:
    [​IMG]
    You can find them in junkyards but typically the driver seat is pretty hacked from the ones that I have found. The ones in the picture are in VERY good condition so if you find a set like this then you are very lucky. They also came in black leather.
    John
  5. Jade Flacon
    Jade Flacon Guest
  6. novanutcase
    2,317
    536
    263
    I don't know about lighter but they definitely hold you in better than stock seats and bolt in without modification. They sit a little lower also.
    John
  7. Jade Flacon
    Jade Flacon Guest
  8. novanutcase
    2,317
    536
    263
    Not sure on 1st gens. I have a 3rd gen and they definitely bolt in.
    John
  9. Jade Flacon
    Jade Flacon Guest
  10. neuspeedescort
    8,122
    94
    348
    wenatchee, wa
    gen1 will be only exp as a direct swap. gen2 and 3 are all mx3 compatible.
  11. novanutcase
    2,317
    536
    263
    I think the easiest way would be to find universal rail mounts and mod them to the car. Then you can mount pretty much any aftermarket seat you want.
    John
  12. Jade Flacon
    Jade Flacon Guest
  13. novanutcase
    2,317
    536
    263
    Why not fabricate some brackets that will adapt your existing seat rails to whatever seat you want to use? Pretty sure a set of front buckets from a 1st gen GT will bolt in.
    John
  14. Jade Flacon
    Jade Flacon Guest
  15. neuspeedescort
    8,122
    94
    348
    wenatchee, wa
    if you use the existing rails and put an aftermarket seat on it. it will likely be taller. buying aftermarket low profile sliders and fabricating a set of mounts may be the only route to go.
  16. novanutcase
    2,317
    536
    263
    Uhhhh…..ok...…
    John
