Lightning's Transformation | Page 10 | Ford Escort Owners Association (FEOA)
Discussion in 'Photo Forum' started by white-lightning, Jul 3, 2008.
  1. white-lightning
    white-lightning FEOA Member
    2,896
    186
    Salem, VA
    [​IMG]
    Got more done. Had an issue with the one water pump bolt/stud. I had to notch the fender apron after tilting the engine to get it to go in. All I need to do now is put the upper rad hose, intake, and battery in. The spi controller needs a power source for it. I think I am going to wire in a fuse holder and run a 15 amp fuse to it.
  2. white-lightning
    2,896
    186
    Salem, VA
    Got the intake manifold on today along with my egr tube and some other stuff. The tube fits tight but works.
    [​IMG]
  3. white-lightning
    2,896
    186
    Salem, VA
    Got my weapon r intake tube cut down and it fits fine. I will hopefully be able to fire it up this weekend.
    [​IMG]
  4. nezwick
    nezwick FEOA Member
    3,149
    288
    Pennsylvania
  5. white-lightning
    2,896
    186
    Salem, VA
    Firing up will happen tomorrow after work. Hope all goes well.
  6. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    we'll keep our fingers crossed for ya!
  7. white-lightning
    2,896
    186
    Salem, VA
    It runs!! I took it out for about a 2-1/2 miles drive to see how it did and to heat up enough to burp the cooling system. I am about to go out in an hour and gas her up.
    [​IMG]
    I need to make a spacer for the dip stick tube in order to put my strut bar back in. I also have a problem that was from before but that is a new thread: https://www.feoa.net/modules.php?name=Forums&file=viewtopic&p=629127#629127
  8. nezwick
    nezwick FEOA Member
    3,149
    288
    Pennsylvania
    Awesome, congrats!
  9. ValleyScort96
    ValleyScort96 New Member
    1,032
    Rio_Grande_Valley
    That's great man. Enjoy.
  10. mc_muench
    mc_muench New Member
    81
    "Miller"waukee
    whats with the 1.9 valve cover you sly devil you?
  11. ValleyScort96
    1,032
    Rio_Grande_Valley
    Don't worry about that valve cover. It looks nice on there.
  12. Craigsnedeker
    Craigsnedeker New Member
    66
    NY
  13. white-lightning
    2,896
    186
    Salem, VA
    I'll have to post some updated pics. I'll do it later this week when I get a "new" part. hehe
  14. white-lightning
    2,896
    186
    Salem, VA
    Here's the "new" part:
    [​IMG]
    At first looking at it I thought the brass fitting would be a problem but it turns out the gauge touches the vc once installed. It doesn't leak right now, but after adjusting to the proper psi and checking for leaks I reinstalled the stock one till I get an extension fitting.
    [​IMG]
    [​IMG]
    Here is an example of the fitting I'll get: http://www.palmer-pursuit.com/cart/index.php?main_page=product_info&products_id=13
    Here is the most current pic of the engine.
    [​IMG]
    Since the pic is small I tell about some other not so noticeable tweaks. I modified the throttle cable bracket to sit 3/8" further back, as the adjustment on the cable was maxed out and still had slack. I also slapped in a modified 3rd gen fuse box bracket as well.
  15. white-lightning
    2,896
    186
    Salem, VA
    Got the extension piece Friday at my local True Value. After $2.61 and some Teflon tape the fpr and gauge are in. I now will know for sure that my fuel pressure is correct, so that it can perform the way it should. I haven't noticed any difference performance wise, so I can assume the the old regulator was functioning properly.
  16. racethisescort89
    racethisescort89 New Member
    2,391
    In your closet watching you secks!
    duude DIRTY build!! +10 !! congrats.
    now VIDS or GTFO lol
  17. white-lightning
    2,896
    186
    Salem, VA
    Update:
    So far I have had no issues with the swap. I did have a cel 800 miles later, but that was due to an egr hose being loose to the dpfe. Right now it gets about 26mpg in town and 36mpg on the highway. I can't complain about it. I have yet to re-gap my plugs the 0.060 I had on the 1.9, which seemed to make a difference with it, so I hope to get a little more power out of this 2.0L engine once doing so.
  18. white-lightning
    2,896
    186
    Salem, VA
    Well last week I had any unusual thing happen. On of my fuel rail's mounting tabs was found broke. So I had it tig welded. My insurance put a new windshield in the week before last due to a rock hitting it. Just got my directional fan-blades and tires on a few minutes ago. Link to tires: http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=Ecsta+AST&partnum=05HR5EAST&vehicleSearch=false&fromCompare1=yes I also have about 2k miles on a new set of Duralast Gold ceramic front brake pads and 1.6k miles on 5w-30 Castrol Edge w/a Fram Extended Guard filter. Being getting on average 34-36mpg so far and even 37.8 once.
    Tig welded fuel rail tab
    [​IMG]
    New tires and wheels on
    [​IMG]
    Worn out Bridgestones (28k miles on them)
    [​IMG]
    Last pic of my parts car
    [​IMG]
  19. racethisescort89
    2,391
    amazing dude. those tires weren't as Bald as Silex's old set haha it was hilarious great work man wish i had money time and patience to do this sorta stuff
  20. The_Jack
    The_Jack New Member
    93
    mounds view, minnesota
    wow dude, i never knew you had this much into your car, very nicely done, and i love the 1.9 vc, its sneaky lol
