Well after searching for an hour or two I still don't have the answer I am looking for. Monday I removed my timing cover and trimmed it and reinstalled it to keep the crank pulley from rubbing it. No more noise from the timing cover at all now.
Now I hear a lifter ticking load upon starting. Once the oil pressure comes up it quiets down significantly, but still is present. I only think it is one, on the intake side, from listening to it. I put some CD2 engine detergent in it assuming it is a sticky lifter. Everything I read from searching seemed to point that I shouldn't worry, but is there any possibility that is doing enough damage to warrant replacing the lifter(s)? How would I find the noisy lifter with out replacing all the lifters or should all be replaced at the same time?
Patrick
Patrick
