1 - 7 of 7 Posts
ok i have a leak between my motor and trans i changed the rear main seal and oil pan gasket and it still leaks it doesn't seem to be my motor oil cause i just put fresh oil in it and this isnt fresh oil leaking what could it be i'm not a mechanic but i know my way around a car pretty good only thing i could think it would be is the seal around the trans shaft
what color is the fluid?
Can you confirm it is leaking engine oil or gear oil? If oil, likely a number of things. From the VC, cam seals, HG, rear main seal, oil pan. If gear oil, most likely an input shaft seal. If oil, I would begin by giving that side of the engine a thorough cleaning with brake clean and compressed air. Get it good clean and dry to notice a leak easier. A rear main seal leak will be hard to see. If gear oil, be prepared to pull the trans.
here are some pics of my car its a 93 mercury tracer 4 door lowered 1.8 inches with kyb gr2 struts and drop zone springs it was a automatic when i got it from my grandma for free lol with only 6XXXX miles on it, it now has almost 89000 original miles trans went out about 2 months ago i did a 5 speed conversion to it and put on a ford escort gt wing i like it want to see what other people think about it
1 - 7 of 7 Posts
