ALL the credit goes to Blade on this one... correct me if I´m wrong:
If you´ve got a plate with 4 bolts on it and something like a cone filter off of that, yes you have to change a few things. First, take out the airbox. This is easy fo´ sheezy ma neezy. there are 3 bolts, one on the firewall side, the other two on the headlight side. I think it takes a 12mm socket or right around there.
Then of course you need to take out the other part of the intake, which is that part that goes from the air filter to the actual intake tube to the manifold. I´ve never done this, but it shouldn´t be too tough.
The hard part is where to put that little orange sensor that previously resided in the box... you´ll have to ask somebody better than me on this.
The MAF sensor is short for "mass air flow" sensor... or something like that. If you open up the airbox and look down the intake tube (towards the engine side) you´ll see a vertical fin running right through the diameter of the pipe. This is your MAF. It detects the amuont of air entering the engine.
A VAF is short for "vane air flow". This is the type of volumetric air sensor used stock on EGTs. This is a poor design because it uses a flapper which does something like restrict flow or something. I dunno, but you don;t have to worry about this.
Concerning the MAF when you do the mod, you shouldn´t have to touch it. Just bolt that plate onto it, that´s all.
What you are probably thinkng about is that little orange bulb that was in the upper housing of the airbox. I dunno what you should do with this.
And blade told me last night that despite the fact that you´re taking warmer air, it´s actually not thaty much warmer. I dunno for sure. Chances are it will still be an improvement over stock.
He said that on his friend´s car, installing a colt air intake improved his 1/4mile from 17.9 to 17.8, so it doesn´t really make a difference.
hope that somehow a fellow LX owner (me) could have helped ya out
I´m getting new tires today, if anybody cares! w00tz0r!!1
