1 - 3 of 3 Posts
Allright, I recentaly bought a 97' wagon with the 2.0 and auto trans. I'm looking to upgrade the car as much as I can for as little as possible. I need info on parts I can get at the junk yard to increase performance. I already know about the rear sway bar and I have heard stories form a friend that ford made stock headers for GT's that would fit. I would appriciate any info that can be provided. I know that someone out there like's recycling. Thanks
80s escort gt on the 1.9 motors they have a 4-1 header most yards charge like 20-40 bucks.
check the sway bar first, you have a wagon so they usually already run a heavier swaybar for the weight, if not chack a 91-96 wagon sway bar, or check with barend
G
If your going to be messing with the exhaust manifold & switching to header's..Here's a little tip from my racing day's...Take your exhaust gasket & trim the holes so they are flush with the exaust ports...It will create an easier exhaust flow & therefore increase in horsepower..If you have the time..you can also polish your exhaust ports..
1 - 3 of 3 Posts
