Choose July 2009 COTM
  • #1 therieldeal
    Votes: 0 0.0%
  • #2 greddy1387
    Votes: 0 0.0%
  • #3 white-lightning
    Votes: 0 0.0%
  • #4 krux
    Votes: 0 0.0%
  • #6 hadoken
    Votes: 0 0.0%
  • #7 mellowness65
    Votes: 0 0.0%
  • #8 madmatt2024
    Votes: 0 0.0%
Status
Not open for further replies.
1 - 9 of 9 Posts
Category is - Best stock look - Best underhood mods
prize: $25 giftcard to Autozone OR AdvanceAuto (winners choice)
vote will last for 8 days -
may the best Scort/Tracer win!
Matt.
I will hold my vote till the end in the event of a Tie -
winner will be notified via PM and in COTM post, mailing address must be forwarded for gift card to be sent.
Please remember to post any comments in the "COTM Discussion" thread and not in this nomination/Poll thread, thank you.
Discussion Starter · #2 ·
nomination #1 therieldeal
Engine modifications -
Mazda 323 GTR engine, MegaSquirt II, 3" Stainless steel downpipe, 3" catback with Magnaflow components, Tial wastegate, massive 3.5" thick FMIC, HKS SSQV BOV, Greddy Profec B SpecII EBC
Drivetrain Modifications -
ACT HD pressure plate, Spec stage 3+ disc, lightened stock flywheel, Quaife LSD, custom built (by yours truly) hybrid 97 kia/97 escort transmission
*blew up 3rd gear*
Now i'm working on swapping in a toyota gearbox, from a v6 camry of all things... stay tuned.
Suspension Modifications -
Ground Control coilovers, Cusco front Camber plates, ZX2 S/R struts, ALL poly suspension bushings, ZX2 front/ST rear swaybars, Josh_LX™ delrin swaybar endlinks, front/rear lower tie bars
Brakes -
KVR brake pads, Corksport SS brake/clutch lines, Brembo rotors (3rd gen protege up front)
Interior Modifications -
MX3 SE black leather seats, black carpet, black mx3 lower dash & center console
Stereo-
Pioneer head unit, Blaupunkt component speakers
Exterior Modifications -
BG Protege LX side mirrors, clear marker lights
Wheels/Tires
(4) Stock '01 Miata wheels with BFG G-force Sport's, (2) 15x7 Roh alloys with Hoosier 225 50 15 Drag radials for the track
The Result-
12.28 @ 117.2 mph, backed up by multiple 12.4x runs
here are some pics...
#2 greddy1387
1996 Ford escort LX
performance:
zx2 motor and tranny swap
cold air intake
ported throttle body
short throw shifter
polyurathane shifter bushings
strut tower bar
mx-3 tie bar
2 1/4 custom catback exhaust
exterior:
x-bomber body kit (thanks dave ) lol
rear tinted windows
tinted corner markers
Tinted yellow markers on tails
Custom accord m3 mirrors
gt grille
gt 3 peice spoiler
#3 white-lightning
1996 Ford Escort Lx
125,441 miles
Engine/ Drivetrain:
-Castrol Syntec w/ K&N oil filter
-Magnetic oil drain plug
-MSD coil w/ Ford Racing 9mm wires and Autolite Iridium plugs @.060" gap
-Optima D35 Yellow Top battery
-Weapon R and K&N intake
-2.0L SPI throttle body swap
-Cork Sport bronzoil shift bushings
-TWM short throw shifter and knob
Suspension:
-full rear Energy Suspension bushings
-Energy Suspension shift stablizer bushing
-EGT rear sway bar
-EGT rear disk setup
-Tokico struts and Eibach springs
-Cork Sport front and rear stb
-Mx3 rear tie bar
Looks:
-EGT side skirts
-EGT fuel door/hatch release
-EGT grill
-Mx3 shift boot
-Mx3 rear center console
-Protege Lx power mirrors
-E-Bay clear corner lenses
#4 krux
Mod List:
Engine
-Valve Cover 98 Swap
-Fuel Rail 98 Swap
-Iceman Intake
-Ported Throttle Body
-Zxtuner Udp
-LXQ1 Swapped Ecu
-Sct 4 Positive Switch Chip
-Zex Nitrous Kit
-Crower Intake Camshaft
-Kamikaze Header w/ 2.5 Down pipe
-Trubendz Catback Exhaust System 2.25 W/Magnaflow Muffler
-60mm TB(by OEM)
-Ported Intake Manifold
Exterior
-Wings West Kit
-Drag 17" Rims
-Kumho Esta's 716 Tires(205/45/R17)
-Painted Calipers, Drums, Sway Bar (If you look even the knobs on brakes are polished)
-19mm Escort Rear Sway Bar
-Progress Springs
-Tockio Struts
Interior
-Twm Short Shifter
-Svt Shift Boot
-S/R Shift Knob
-Sony Head unit
-Rockford Fosegate Amp
-Power Acoustics Capacitor
-Pioneer Shallow Sub (Custom Made by SeriousZx2)
-A/F Gauge & Amp Temp Gauge
-Fiberglass Switch Panel
-Corbeua Racing Seats
-Crow Racing Harness's
-Custom Made Display Boards
-Harness Bar
2005 dynoed at 161whp 185lbs torque (Timing was 2 degree's bad tune can make much more now) - Old setup
Soon she will hit around 200whp and around 220 lbs torque with upping the jets , new cam in and soon to be modifying a Crown Vic tb and Porting the Intake Manifold.
#5 foundnemo25
1994 LX 2.2 SPI TURBO
T3/T4 .63 TRIM TURBO
CUSTOM TUBULAR MANIFOLD
3.8 TB SWAP
TIAL 50MM BOV
TIAL 46MM WASTEGATE
PORTED AND POLISHED HEAD
3 ANGLE VALVE JOB
SRT-4 690CC INJECTORS
EFP ADJUSTABLE CAM GEAR
ISKY COMBINATION CAMSHAFT
ESCORTFOCUS HYD TAP LIFTERS
ESCORTFOCUS DOUBLE VALVE SPRINGS AND SEALS
WEISCO 2.2 FORGED PISTONS
ARP HEAD STUDS
ARP MAIN STUDS
MS V3 FUEL MANAGEMENT
FMIC
BD UNDERDRIVE PULLEY
FIDANZA 7LBS FLYWHEEL
SPEC STAGE 3+ CLUTCH
20PSI 371WHP 422FTLB
#6 hadoken
Mazdapeed Miata oil cap for the bling factor. MSD Blaster 2 coil. Taylor Thundervolt wires. I think it has a B-code VAF on there but its painted black so I can't see the letter. Ceramic coated Pacesetter 4-1 header with Stainless steel flexpipe. It's got a Pacesetter exhaust too, which sounds horrible. By end of summer I should have Megasquirt installed and be running a GSXR1000 IRTB setup that came off of a Miata, with HKS cam gears.
TWM short throw shifter. AWR 95 durometer trans mounts. JRally solid poly passenger mount.
I have an MFactory helical LSD from the group buy currently being packaged and shipped to me that will be installed in a rebuilt transmission using a Mazdaspeed 3-puck sprung hub clutch kit with a 323 GTX flywheel.
Cusco AS front strut bar. Corksport Type II rear strut bar. MazdaRacer tie bars. Cusco adjustable camber plates. Ground Control coilover sleeves. ZX2 S/R struts. KONI Specials are sitting under my bed waiting to be installed along with my Quikor 1" rear sway bar and MX-3 rear TTL's with Super-Pro bushings.
Brakes -
New OEM parts
CDM Manual Seat Belts. Mazdaspeed Protege Pedal covers, MX3 seats. MX3 center console with extended height arm rest. Protege cup holders. white face gauges
spoiler removed
Wheels/Tires -
O.Z. Racing Crono HT 15"x7" +37mm offset with 195/55 r15 Dunlop Direzza Z1 Star Spec
Discussion Starter · #8 ·
#7 mellowness65
1998 Denim Blue ZX2
Drivetrain
Candy Blue Valve Cover
Vibrant Strut Bar
Iceman Intake
Converted to 6 Wire Maf setup
Esslinger Engineering Crank Pulley
ZXTuner Alternator Overdrive Pulley
Ford Racing/1999 S/R "NGP0" PCM
Hotshot/ZXTuner Header
2.5" Trubendz Exhaust with Borla ProXS Muffler
Ford Racing Plug Wires
MSD Coil
MTX Swap
Corksport Stainless Clutch Line
Corksport Bronzoil Shifter Bushings
Energy Suspension Stabilizer bushing
K&N Air Filter
Centerforce Clutch
Gates Racing Timing Belt
EV6 Injectors
Braking/Suspension
S/R Struts
Dropzone Springs
Akita 17x7 Wheels
NeoGen tires in front, Exclaim UHP's in back
S/R Rear Disc Conversion with Powdercoated Rear Spindles & all 4 Calipers rebuilt and powdercoated candy blue
Correct S/R Mastercylinder w/ rear disc prop. valve
Axxis Ultimate Pads
R1 Concepts Drilled & Slotted Rotors
R1 Concepts Braided Stainless Lines
Speedbleeders at all 5 points
Powdercoated 19mm Rear Sway Bar w/ ES Endlinks and Bushings
Upgraded Endlinks on Front Sway Bar
Exterior Appearance
OEM-Style Carbon Fiber Hood
Dark Chrome Tail Lights
Black Housing lights w/ Amber Reflectors Removed, Inner Turns done to match
Hidden Radio Antenna
OEM Fog Lights Added
35% Tint
Interior
Dark Charcoal Interior Swap w/ Lt. Gray Highlights
Power Windows Added
ZX2 Leather Rear Seats
MX3 GS Limited Leather Front Seats
S/R Gauges
TWM Shifter
TWM 600 Gram Shift Knob
Ford Racing/ZX2 S/R Leather Shift Boot
Pioneer CD/MP3 Player
OEM Ford Vinyl Mats
I bought the car in August '06 with 35k miles on it. It had 2 options: 14" alloys and automatic transmission.
Discussion Starter · #9 ·
#8 madmatt2024
97 LX Wagon
Engine -
Custom Air intake.
EFP 25% UDP.
Neon 2 1/4" exhaust with Flowtech Red Hot glasspack and Magnaflow XL Turbo Muffler.
Painted valve cover.
Soon to have custom shorty header.
Transmission -
Ebay short shifter.
Handling -
EGT rear swaybar.
Front and rear strut bars.
Yokohama Avid H4S tires on stock rims.
Interior -
Custom leather shift boot.
Pioneer DEH-P3700MP headunit in Scosche dash kit, Kicker 6.5" in front and Alpine Type S 5"x7" in the rear, all with 100 Hz Base blockers. Audiobahn 8" Sub in custom tuned enclosure with 300W Kenwood amp.
Factory cruise control added from junkyard.
A/C deactivation switch.
Scangauge II.
Power door locks added.
Exterior -
2nd gen tracer tail lights.
3" stainless exhaust tip.
Polished headlights.
Driving lights.
1 - 9 of 9 Posts
Status
