sweet! I need to keep my eyes open for one of them. It could come in extremely handy. Thinking about changing Squirts name to Rusty after doing the rotors today... holly cow lol
What's everone's opinion on using TWO sets of ramps?? My shifter dropped and I'm going to mess with it soon. I'd drive the front tires up on my first set of ramps, then jack up the rear and stuff my second set of ramps under the rear tires the opposite way. Then leave my largest floorjack almost 100% raised under the rear crossmember as a backup, and jackstands almost 100% raised under somplace in the front as a backup-backup. I'm STILL leery about this idea, but there's not enough room for both me AND tools in the shifter area unless I get the entire car up in the air. I have this bracket on the way: http://mx-3.com/phpBB3/viewtopic.php?f=39&t=44745&hilit=anti drop&start=60
Yeah it's beast. Took off rusted tractor trailer lugs easily. Sat 10+ years. 1 1/2" hex. Popped 167k mile, 18 year old head bolts with just a little hammering. Beats twisting them off with a breaker bar. It's expensive, but it's a lot of gun. So it's not overpriced.
As long as you're on solid, safe ground, I don't see a problem with that. I had my scrapper on ramps + jack stands for awhile and it was fine. You could, however, accomplish the same thing by screwing 2x8s together if you don't already have ramps.
ZZ, looks like that car was on four small solid concrete blocks... too small to wheel-chock ? How is this person blocking the wheels ?
Good point. You have redundancy. While I would trust the trans to hold the car alone, I wouldn't trust the hand-brake. There was a time or two when I pulled and set it sort of the edge of the teeth. Minutes later, (still sitting in the car,) I witnessed it snap-loose and slam to the full-release position.
I'd trust 4 ramps more than 4 jack stands. Ramps are much more stable, at least the ones I use. Jack stands must extend much farther compared to their footprint.
I use my 1/2" Milwaukee impact like this. Sold my $10 jack that could never bleed right for $10. My problem with jackstands for this car is getting em up high enough. I know you guys are gonna want to burn me for this. Also seeing as how the frame rails are not a frame and crush, I rarely use the stands unless I plan on working for hours. I generally use 2 jacks to compensate for no stands. But I should get another scissor or two with the hext bolt so I can quickly hit em with the gun.
