silverton said:
oops. i guess rwd vehicles are set up just a little different. sorry!
No they aren't, Silverton.. you're just flat wrong.
Master Cylinder - Hydraulic Control Part that is engaged by the physical motion of the pedal.
Slave Cylinder - Hydraulic Control Part that is engaged by the fluid pressure produced by the MASTER Cylinder (hence the phrases master and slave).
On ALL Vehicles regardless of the drive wheels, the Clutch MASTER is engaged by the clutch pedal (usually at the firewall) and the Clutch SLAVE is engaged by the Clutch Master (usually at the transmission, but on some vehicles.. INSIDE the transmission).
"Technically" the Brake Wheel Cylinders and Calipers could be considered Brake Slave Cylinders.. but it's not the commonly known industry term for those.
