Drivetrain - Is it ok to leave the transmission exposed for a few days... | Ford Escort Owners Association (FEOA)
Drivetrain Is it ok to leave the transmission exposed for a few days...
Discussion in 'Drivetrains' started by axa, Aug 5, 2020.
  1. axa
    axa FEOA Member
    296
    54
    178
    having just refilled my 5 speed transmission, due to slow leak... i then did something stupid that lead to cv boot breakage...
    Figured i should pull the axel and replace the seal anyway.
    What i used to do when my speedo gear didnt want to come out, was tip the transmission to the side, fill up 3 quarts of atf and assemble...
    Well i pulled the bad axle waited a few days for the new one to come in... but no i realize i left the transmission exposed for a few days... is it hydroscopic? is it absorbing water? did i ruin the fluid by doing this?
  2. marclar
    9,095
    624
    seabeck WA
    it will be fine. all oils are hydroscopic, brake fluid especially. but it will be fine. i wouldnt worry
  3. zzyzzx
    15,242
    1,237
    I would be more concerned with crap (insects, dirt) getting into the transmission from the open hole.
  4. denisond3
    10,193
    2,869
    Any amount of water will just get boiled out - as you drive around. I wouldnt want to let it sit too long before driving it.
    A fair amount of moisture gets sucked into a warm transmission as it cools down at the end of a day of use. The only problem would be if the transmission had to sit unused for weeks or longer.
  5. axa
    axa FEOA Member
    296
    54
    178
    thanks for the confirmation... its funny as i do this the 3rd 4th 5th time i tend to take more care as time goes on
  6. axa
    axa FEOA Member
    296
    54
    178
    delete
