is it just my luck, or do these cars eat alternators? | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in 'Reference Material' started by Andrew_1122, Nov 16, 2006.
  1. Intuit
    Intuit FEOA Member
    7,545
    924
    Southwest Ohio
    Unfortunately I had ignored the squealing noise for at least several months before it finally started to exhibit charging issues.
    It was FordMan59 who clued me in on replacing the alternator brushes at around 220 or 230k.
    I found that the old worn brushes had severely damaged one of the commutator.
    http://www.bing.com/images/search?q=commutator&qs=n&form=QBILPG&pq=commutator&sc=8-9&sp=-1&sk=
    So after replacing the brushes as FordMan59 had suggested, only got another 20k or so out of it.
    Had I not ignored the squealing noise, would still be running on that OEM.
    The alternator that replaced the OEM lasted 1-2 years; cooked itself quite well. (fortunately maintained the normal 14.4v and below output until it quit) This was an alternator purchased from NAPA, lifetime warranty, Motorcraft casing, rebuilt by Raybestos. Upon initial return was told they no longer stock or deal with Raybestos and would have to wait a week or two for the old alternator to be shipped-out in exchange with them. Not willing to wait that long, asked for a refund and was denied.
    Went and got an alternator from CarQuest and it seems to be of excellent build quality. It came with detailed documentation, including spec-by-spec test result numbers. It was definitely a lot heavier than the Raybestos crapola. Maybe a week after installing the CarQuest alternator, went back to NAPA, told'em I couldn't wait and had already installed an alternator from elsewhere; again asked for a refund. The second time they granted it! It is an independently owned shop and was purely at the manager's discretion.
  2. millball
    millball FEOA Donator
    1,329
    251
    233
    Southern AZ
    Can you say arc welder.
  3. Supersedona
    Supersedona FEOA Member
    269
    64
    58
    Reminds me of my tractor setup. Externally mounted starter/generator and internally mounted alternator stator, separate independent regulators on each for twice the power accessories ;)
  4. cajunscort96wagon
    cajunscort96wagon FEOA Member
    61
    19
    18
    that multi alt setup is probably on a lowrider with a hell of an audio system.. those hydralic pumps draw hellacious current.... looks like he has 3 100 amp ones and a 65 amp
  5. Intuit
    Intuit FEOA Member
    7,545
    924
    Southwest Ohio
    FYI, after parking over a sewer with some pretty corrosive gasses exiting for several months, mine started eating alternators in 15 minute intervals. It was an overcharging issue; alternator running at full-field, full-output regardless of battery voltage or charge level.
    https://www.feoa.net/threads/alternator-not-charging.91409/#post-836929
    Voltage drop testing with none of the accessories on, engine revved, identified a 0.419v loss between alternator casing and battery negative terminal. Combined with voltage drop on the positive side of 0.8 peak with nearly all accessories on, could've been looking at a 1.5v easy, overall voltage drop. I was reading >15v output on the alternator.
    Problem resolution with photos is in the above link.
  6. Modtronix
    Modtronix FEOA Member
    20
    13
    This. On point. Have a 2nd gen and a Saturn great car but fixing stuff on it...
    Sent from my SM-N910P using Tapatalk
  7. dchawk81
    dchawk81 FEOA Member
    3,450
    940
    173
    I had to swap the alternator out on mine when I had it. Fortunately I already had one from a junker.
    But yeah I've had to buy alternators for more than one car in my life. Starters too.
