Here is some history. I recently did a head swap on the 94 due to a crack in the exhaust port. I purchased a 91 parts car that had a low mileage rebuilt head on it. The engine seemed to run good when I bought the car but I never drove it due to the transmission being toast (automatic). I decided to swap heads instead of the whole engine as the parts car short block leaked oil and had ~30K more on it then my motor. The head has about 35K on the rebuild. Anyway, I used my manifolds but the other car's cams, injectors, as they were recently cleaned, and the other cars distributor and spark plug wires. I also installed new plugs but everything else was off my car.
I have driven the car roughly 80 miles this week and for the most part it runs fine. The engine light is not on however, there is this wierd hesitation / missing spells that it goes thru. It usually occurs when I bog the engine in second gear. You feel the car hesitate as it is accellerating and then 5 seconds later it goes away and the car takes off. THis happens once or twice a day. It has also happened once when I started the car. The car started, idled real rough and died. I started it again and it barely caught but was still running rough. I got out of the car to check for smoke and there was none. After about 20 seconds, the roughness went away and it idled fine.
I am stumped here..... I have not noticed any smoke when the car has these spells so I assume the fuel system is ok. I am thinking it could be ignition related. What do you guys think?
I plan on checking the cap for moisture as I have had a similar problem like this before. If it looks fine I may swap distributors to see if the problem goes away.
Any other ideas?
Any other ideas?
