1 - 6 of 6 Posts
i have no clue but im bored so ill take a stab.... short ram sounds like its ramming the air in (more air=more hp) and cold air gets u about stock ammount of air just its just cooler so that = hp. does that sound right? no clue...
Ram air usually is a shorter setup, but if I'm not mistaken, there's a vacuum that actually pulls in the air.
A cold air intake would just be like placing your intake filter underneath the bumper to get the coldest, most dense air possible.
Pretty much both right.
A ram air setup does what it sounds like it does, it puts the beginning of the intake tube where air gets rammed into it while you're driving, like a hood scoop would.
A cold air intake has the opening for the intake at a place where it will draw in cool, dense air, i.e. - the bumper.
Another possibility for a short ram intake is an intake that is shorter than the stock one. This allows the air to travel faster and in some cases (think velocity stacks on an old V-8) can be tuned. The idea behind a ram intake is to find the length that matches the engines natural power band. If you can find that length (insert lots of physics here) the engine gets a "ram" effect - it gets more air than it normally would. Those old velocity stacks are are a form of ram induction. When properly tuned velocity stacks have yielded volumetric effiecency numbers around 105-112%. Really amazing since numbers over 100% are typically reserved for superchargers and turbos. But it proves that you don't need forced induction to get more air into the engine.
Also, the longer an intake is, the more the throttle response suffers because it takes more time for a longer column of air to accelerate. The problem with a short ram intake on a street car, is that getting cool outside air into it is hard... so often people end up installing a short intake that, while theoretically allowing more air to enter.. the air is far less dense thanks to the underhood temperatures. A racecar can remove headlights.. cut ducts, etc to get cold air into a short intake. It's a tradeoff either way.. but on a streetcar, a well tuned cold air intake with a resonance chamber (a larger volume of air closer to the throttle plate for better response) is usually the best compromise for a street car. Oh, and a short intake will be the loudest... making it sound faster.
1 - 6 of 6 Posts
